Runs rough and stalls when engine damp
Old Feb 16, 2012 | 10:07 AM
PCRoger's Avatar
PCRoger
Default Runs rough and stalls when engine damp
On mornings of fog recently, moisture on everything, our 97 T&C (179,000 miles) will run rough and even stall until it warms up ( minute or two ).
We replaced plug wires once before, do you suppose that is the fix for this or could it be something else?
Seems to run fine once warmed up.
thanks.
Old Feb 17, 2012 | 12:47 AM
papaduck's Avatar
papaduck
The plug wires are the first thing I would check or replace.
Old Feb 17, 2012 | 10:51 PM
steak59's Avatar
steak59
no code? CEL?
Old Feb 22, 2012 | 04:11 PM
ShelbyGT550's Avatar
ShelbyGT550
When its running rough bring the van into somwhere that is dark. And look under the hood at the wires. If you see sparks jumping then you need wires.
Old Feb 22, 2012 | 07:26 PM
PCRoger's Avatar
PCRoger
No error codes; and after running a minute it seems fine.
Problem is it's never dark at the time ...
thanks
