2001 grand caravan sport fluid ?
Old Feb 26, 2012 | 06:58 PM
caravanman1966's Avatar
caravanman1966
Default 2001 grand caravan sport fluid ?
I just got a Dodge Grand Caravan Sport , and was needing to know what transmission, oil, etc i should use?
It has 220,000 miles and runs good , has a slight oil leak, but i have no idea when the last oil or transmission fluid change was.
thanks
Old Feb 26, 2012 | 07:47 PM
blknblu's Avatar
blknblu
ATF+4 for 2001 and up.
It might be the same for the older ones now as well.
Here is a certified list for ATF+4:
http://www.centerforqa.com/licensedatf4brands.html
If you change the fluid, a drop the pan - replace the filter - is the way to go.
Dorman sells a pan with a drain plug on it for easier service next time.
Old Feb 27, 2012 | 08:01 AM
caravanman1966
thanks for the list.
