no more parking brake
Old Mar 18, 2012 | 06:41 PM
gnickner's Avatar
gnickner
Unhappy no more parking brake
Hi
I just changed my winter tires to summer ones. When I do that I always remove the caliper, pads and clips to clean up all the things and apply anti-sease.
On the rear I use the tool to screw down the piston. After the reinstallation I pumped the brake and was never be abble to get a hard pedal. The pedal always went down to the floor. I checked the oil, it is good.
So I jacked the van again to see what happened. I saw the caliper was moving freely on the pin, it acted like when I pressed the brake the piston got out and when I released the pedal the piston retracted.
At this point, I decided to start over and use the tool again to screw the piston back in place. After that, I pumped the brake and it worked great. I saw the piston going out and turning and after a few pumps the piston seated and worked well.
But now, if I use the parking brake the mecanism works but no brakes are applied (the piston doesn't move).
I followed all data procedures. I'm completely lost on what I have done wrong. Please HELP!
Thanks for advise,
Old Mar 19, 2012 | 08:52 AM
Tizzy1's Avatar
Tizzy1
The calipers are bad and need to be replaced. I have seen this many times. In the future I would recommend you only mess with the rear brakes when you have to.
Old Mar 19, 2012 | 07:00 PM
gnickner's Avatar
gnickner
Ok bad news.
Do you have a idea of what I do wrong? Curently It act normaly for brake operation. Is it safe to drive whit it?
I think I can live without parking brake.
thanks for the advise
Old Mar 19, 2012 | 08:35 PM
steak59's Avatar
steak59
You probably screwed it in TOO FAR in on the first try.
it really don't matter, as long as the Caliper is not locking up, you'll be ok. Just make sure every Time you jack up the car for Oil change, spin the rear wheel and make sure it rotates freely.
Who uses parking brake these days?
