bleeding the ABS pump
Old Mar 21, 2012 | 09:48 AM
Topher5150's Avatar
Topher5150
Default bleeding the ABS pump
On my 2000 Caravan I had to replace the brake hose which means I have to replace the brake line going from the hoses to the ABS pump (drivers side, front) Is there a certain way to bleed it or just bleed it like I would do it any other time?
Old Mar 21, 2012 | 10:55 AM
Tizzy1's Avatar
Tizzy1
Just bleed it normally, the only time to worry about the abs is if the air is before it or you replace the hydralic assembly itself
