2003 Dodge Caravan Se, Transmission Trouble
Old Apr 22, 2012 | 02:46 AM
Dodgette's Avatar
Dodgette
Default 2003 Dodge Caravan Se, Transmission Trouble
Car starts, but will not shift into any gear. Has like 85,000+ miles. Scanner came up with these Codes,
PO700, PO734, PO720, PO841, and PO731. Anyone knows whats going on besides telling me my trans is gone. Please Help! Any Info is appreciated.
Old Apr 22, 2012 | 08:26 AM
Cloak's Avatar
Cloak
While the van is idiling are the gears ( 1 2 3 d n r p) all circled?
Mine had the same issue and turned out to be the trans solenoid pack.
Old Apr 22, 2012 | 02:42 PM
Dodgette's Avatar
Dodgette
Thanks for the reply, right now they are not circled. But now to think of it, it has lightened all up in the past but goes off as soon as I put it in gear and occured only few times. Also what I noticed is when I am at a complete stop like at the stop light, the engine feels like it's wanting to die out, so I put it in Neutral give it a little rev and then its fine. Now when the car is in idle, I can hear a little squeaky, clinking noise around the engine/trans area and still won't go into any gear
Old Apr 22, 2012 | 08:59 PM
Dodgette's Avatar
Dodgette
Powertrain Diagnostic Trouble Code Information Stored Codes P0700 Automatic Transmission Control System Malfunction P0720 A/T Output Speed Sensor - Low Output Above 15 MPH P0731 A/T Additional Gear Ratio Error In First Gear P0734 A/T Additional Gear Ratio Error In Fourth Gear P0841 Low/Reverse Pressure Switch Sense Circuit Malfunction Pending Codes P0700 Automatic Transmission Control System Malfunction
These are the codes. HELP PLEASE!!
Old Apr 26, 2012 | 02:24 AM
Dodgette's Avatar
Dodgette
We changed the output shaft speed sensor, changed the trans fluid and filter. Engine check light is off. But now have Code PO736 (Reverse Incorrect Ratio). Car will not move in park position like it suppose too, but goes forward in Reverse. Any help or comment is appreciated. Thanks
Old Apr 26, 2012 | 09:52 PM
maxbaby's Avatar
maxbaby
Start reading thru this...
http://www.newprotest.org/details.pl?1410
