AC problems on 2006 GC
Old May 3, 2012 | 02:09 PM
rcain's Avatar
rcain
Default AC problems on 2006 GC
Rear AC works great 55 deg discharge temp.Front passenger side 70 deg F. driver side has 80 deg with all set on low.could this be a mixing door problem? is it possible to run a self test on hvac control unit.if so how to do it. thanks
Old May 3, 2012 | 03:18 PM
Tizzy1's Avatar
Tizzy1
Probably low on freon. Rear evaperator is almost guarenteed to leak at some point. No real issues with the blend doors or the control head. There is a calibration proceedure, it is as follows......
A/C-HEATER CONTROL CALIBRATION
The A/C-heater control module must be recalibrated each time an actuator motor or the A/C-heater control is replaced. If the vehicle is so equipped, the calibration procedure also includes rear HVAC positions for each actuator motor.
1.Turn the ignition switch to the On position.2.If equipped with the manual temperature control (MTC) system, press and hold the Rear Wipe/Wash and Recirculation buttons for at least five seconds. If equipped with the automatic temperature control (ATC) systen, simultaneously press and hold the Power and Recirculation buttons on the A/C-heater control for at least five seconds. The MTC A/C-heater control Rear Wipe/Wash button light emitting diode (LED) and Recirculation button LED, or the ATC A/C-heater control Delay and Recirculation graphics will begin to flash when the calibration procedure has begun.3.The calibration procedure should take less than two minutes to complete for the manual A/C-heater control, and less than twenty seconds for the ATC A/C-heater control. When the LEDs or graphics stop flashing, the calibration procedure is complete.4.If the LEDs or graphics continue to flash beyond the two minute (manual) or twenty second (ATC) calibration time, it indicates that the A/C-heater control has detected a failure and a Diagnostic Trouble Code (DTC) has been set. Refer to Body Diagnostic Procedures to perform further diagnosis. The LEDs or graphics will continue to flash even after the ignition switch is cycled Off and On, until a successful calibration is completed or until the vehicle has been driven about 13 kilometers (8 miles).
