right rear tail light stays on?
Old May 21, 2012 | 11:06 AM
micmax's Avatar
micmax
Default right rear tail light stays on?
Can anyone help me with this problem. I shut off the vehicle and the right rear taillight stays on.
Old May 21, 2012 | 08:57 PM
Cougar41's Avatar
Cougar41
There's a whole lotta difference between a 1984 model and a 2012 model. What's yours?
Old May 22, 2012 | 04:53 PM
lovvorn's Avatar
lovvorn
Default Start with fuse circuits !
Hi , Brake pedal , Take your hand an pull up not down while the wife is giving a on or off tail lite . Then start pulling fuses one at a time . If it was the brake lite adjust the switch . The brake light was the easist an the turn signal switch will be next then the flasher relay . Good luck . Lovvorn
Old Jan 20, 2014 | 11:19 PM
dlischynski's Avatar
dlischynski
Had the same thing on a 2003 Grand Caravan. Also, when I pressed the brake pedal, the center brake light and both taillights stayed on. Disconnected the factory trailer harness and all is well...must be a short or water/snow in the trailer connector.
Old Jan 21, 2014 | 05:00 PM
2013 Grand_caravan SE_17s's Avatar
HuH! lol
