Need help non running Caravan
Old May 23, 2012 | 10:17 PM
crashradius's Avatar
crashradius
Default Need help non running Caravan
Hi I have a 92 Caravan 3 liter auto trans. I am baffled, the van will fire when you turn the key but when you release the key it stops. Checked all relays I could find they all check out good on the bench, I need to know where to look.
Thanks Crash
Old Jun 7, 2012 | 12:53 AM
mbrahmer's Avatar
mbrahmer
Need to test the PCM to see if it's working with the injectors and coil pack. You need a good scanner to do this; I use an auto enginuity unit. Found that in my 96 that the coil drivers were dead on the 3rd computer. Got a new one and it's been fine.
