passenger window wont move
Old May 24, 2012 | 11:08 AM
beckman's Avatar
beckman
Default passenger window wont move
hi guys i have a 2001 dodge caravan and the passenger window wont go up or down drivers side window works fine but no movement from passenger window from drivers switch or passengers switch any help would be greatly appreciated thank you
Old May 25, 2012 | 04:12 AM
Cougar41's Avatar
Cougar41
Likely the motor is toast. Best to change the whole window regulator assembly. You can verify this by checking for 12vdc at the motor connector with the switch thrown. If it's there change the assembly. Around $60. In the mean time try holding the switch up/down and slam the door. It may come back alive at least for a while.
