Factory radio won't turn off - kills battery
Old Jun 1, 2012 | 03:00 PM
Grey County Boy's Avatar
Grey County Boy
Default Factory radio won't turn off - kills battery
I recently purchased a 2005 Grand Caravan, with a AM/FM Tape/CD and 6 disc DVD system. I found that someone had decided to use the tape deck as a piggy bank, and it was causing the unit to keep switching from tape to radio and back. I took out the unit, fished out the change ($2.38 worth), and put the unit back in. I did not, however, disconnect the battery prior to doing.Now it does not turn off with the key out and door opening. I can turn it on with out a key, and the clock stays on all the time. It is killing the battery. I have checked every wire, connector and fuse that I can get at, to no avail. Does anyone have any idea how to fix this?
Old Jun 4, 2012 | 11:09 AM
Tizzy1's Avatar
Tizzy1
new radio, the change inside the radio shorted something out on the circuit board causing your issue. Time to go radio shopping.
Old Mar 5, 2021 | 08:38 PM
knowrules's Avatar
knowrules
Default Nah not an answer..
I have a stock radio same issue..& I can't set the time.
