Changed out Power Steering Pump but not working!
Old Jun 3, 2012 | 08:16 PM
fief1138's Avatar
fief1138
Exclamation Changed out Power Steering Pump but not working!
I spent over 8 hours changing out my power steering pump in my 2000 dodge grand caravan sport. When i first started it up the steering was easy and smooth with turning it side to side. But it only took less then a quart of fluid. I am not sure if it is supposed to take more then that. then after a few minutes the turning became harder and harder. Now it is not working. I let it sit overnight and found that some fluid did drip down into. I am not sure if there is something else I should do to bleed it. Any special way besides turning the wheels? Is it possible it is a defective Pump I bought or something I forgot to to do? This pump comes with a built in reservoir, so I am not so sure it could be a clogged reservoir. There are no leaks either.
I'm flippin pullin my hair out over this. I don't want to have to strip it out again! any help would be much appreciated.
Also, since doing this I am getting a loud clattering sound in the engine that only comes on now when I turn on the AC. any chance I did something in the engine that could cause this while working on the pump?
Old Jun 3, 2012 | 09:04 PM
joe_83's Avatar
joe_83
Not sure if this will help but here is detailed instructions on pump installation. Source: Dodge/Chrysler tech.
Just in case you missed a step.
POWER STEERING PUMP (3.3L/3.8L ENGINE)
NOTE: Before proceeding with this procedure, review the SERVICE WARNINGS AND CAUTIONS at the beginning of the REMOVAL AND INSTALLATION section.
REMOVAL
Remove the (-) negative battery cable from the battery and isolate cable.
Remove cap from power steering fluid reservoir.
Using a siphon pump, remove as much power steering fluid as possible from the power steering fluid reservoir.
Raise vehicle on jack stands or centered on a frame contact type hoist. See Hoisting, in the Lubrication and Maintenance section of this service manual for the required lifting procedure.
Disconnect the oxygen sensor wiring harness from the vehicle wiring harness. Access to connection at vehicle wiring harness is through the oxygen sensor wiring harness grommet in the floor pan of the vehicle
NOTE: The exhaust system needs to be removed from the engine to allow for an area to remove the power steering pump from the vehicle.
Remove the catalytic converter from the exhaust manifold. Then remove all the exhaust system hangers/isolators from the brackets on the exhaust system.
Move the exhaust system as far rearward and to the left side of the vehicle as possible Exhaust Position For Removing Power Steering Pump
Raise the heat sleeve on the power steering hoses to expose the hose to steel tube connection. Remove the hose from the power steering fluid return line on the front suspension cradle Power Steering Return Hose At Return Line Allow the remaining power steering fluid to drain from the pump and fluid reservoir through the removed return hose.
Remove the accessory drive splash shield Accessory Drive Splash Shield
Remove the serpentine accessory drive belt from the engine Serpentine Drive Belt And Routing See Cooling, Group 7 for detailed removal procedure.
Remove the power steering fluid supply hose coming from the remote fluid reservoir, from the fitting on the power steering pump Power Steering Hoses At Power Steering Pump Drain off excess power steering fluid from hose.
Remove the power steering fluid pressure line Power Steering Hoses At Power Steering Pump from the power steering pump. Drain excess power steering fluid from tube.
Remove the power steering fluid return hose Power Steering Hoses At Power Steering Pump from the power steering pump. Drain excess power steering fluid from tube.
Remove the support bracket at the rear of the power steering pump attaching the pump to the rear of the engine Power Steering Pump Support Bracket
Remove the 3 bolts mounting the power steering pump to the alternator/power steering pump and belt tensioner mounting bracket Power Steering Pump Mounting Bolts
Remove the power steering pump from its mounting bracket.
The power steering pump is removed from the vehicle by pulling it out through the exhaust tunnel area in the floor pan of the vehicle.
If transferal of the power steering pump pulley is necessary, refer to DISASSEMBLY AND ASSEMBLY in this section of the service manual.
INSTALLATION
Install power steering pump back in vehicle using the reverse order of its removal through the exhaust tunnel are of the vehicle.
Install the power steering pump on its mounting bracket. Install the 3 power steering pump mounting bolts Power Steering Pump Mounting Bolts Tighten the power steering pump mounting bolts to a torque of 54 N·m (40 ft. lbs.)
Install the support bracket attaching rear of power steering pump to engine Power Steering Pump Support Bracket Tighten the nut and bolt holding the strut assembly to bracket and the intake manifold stud to a torque of 54 N·m (40 ft. lbs)
NOTE: Before installing power steering pressure hose on power steering pump, inspect the O-ring on the power steering pressure hose for damage and replace if required.
Install the power steering fluid pressure line onto the output fitting of the power steering pump Power Steering Hoses At Power Steering Pump Tighten the pressure line to pump fitting tube nut to a torque of 31 N·m (275 in. lbs.)
Install the power steering fluid, low pressure return hose on the power steering pump low pressure fitting Power Steering Hoses At Power Steering Pump Be sure hose clamps are properly reinstalled.
Install the power steering fluid supply hose from the power steering fluid reservoir, on the power steering pump fluid fitting Power Steering Hoses At Power Steering Pump Be sure hose is clear of accessory drive belts and all hose clamps are properly reinstalled.
Install the serpentine drive belt Serpentine Drive Belt And Routing See Cooling, Group 7 for detailed installation procedure.
Install the power steering fluid return hose on the steel tube at the front suspension cradle Power Steering Return Hose At Return Line
Install a screw type hose clamp on the power steering hose to steel tube connection. Be sure hose clamps are properly reinstalled. Tighten the screw clamp to a torque of 2 N·m (18 in. lbs.)
CAUTION: The protective heat shield sleeves must cover the entire rubber hose and hose to tube connection portion of both the power steering fluid pressure and return hoses Power Steering Return Hose At Return Line This is required to keep the power steering hoses from becoming overheated.
When used, properly position the protective heat sleeves on the power steering hoses Power Steering Return Hose At Return Line Then, tie strap the heat sleeves to the power steering hoses to keep them in their proper position.
Install the exhaust pipe on the exhaust manifold. Install all exhaust system hangers/isolators on the exhaust system brackets.
Connect the oxygen sensor wiring harness to the vehicle wiring harness. Install wiring harness grommet in the floor pan of the vehicle.
Install the accessory drive splash shield Accessory Drive Splash Shield
Lower vehicle.
Connect the negative battery cable on the negative battery post.
Perform the POWER STEERING PUMP INITIAL OPERATION service procedure listed in this section to properly fill and bleed the power steering system.
Inspect for leaks
Old Jun 4, 2012 | 09:26 PM
steak59's Avatar
steak59
What engine? is the pump whining?
Most p/s pump you buy from part store doesnt come with Pulley, was it SUPER tight when you press it in? and how did you install it? maybe your pulley is slipping on the shaft.
when you change a pump, it roughly only takes 1/2 - 1 quarts of fluid.
Old May 23, 2025 | 05:48 PM
bryson's Avatar
bryson
Default Thanks a lot Joe
I tightened the power steering mounting bolts to 40lbs as instructed and proceeded to break the fuking bolt in half…
