04 Caravan radio,wipers,lights out when engine runs
Old Jun 4, 2012 | 11:42 PM
emodo's Avatar
emodo
Default 04 Caravan radio,wipers,lights out when engine runs
Hi everyone,yesterday i start my van and notice that radio,power outlet,wipers,lights not working(may be even more things).Put into gear-rough.On idle seems ok.Shut it off-radio,wipers,etc -everything works!Any idea?!
Help!!Please!
Emil
Old Jun 5, 2012 | 01:43 AM
Cougar41's Avatar
Cougar41
The Integrated Power Module (IPM) is a known corrosion magnet. It's your fuse box. Try a wiggle check on it and see if anything comes alive. Disconnect the connections and inspect for any signs of corrosion. Disconnect the negative battery cable first. Clean with electrical contact cleaner.
Old Jun 5, 2012 | 08:37 AM
emodo's Avatar
emodo
Smile
Thanks for the quick replay,Cougar41 i am going to try that ASAP and will let you know what happens !?Regards Emil
Old Jun 6, 2012 | 09:36 AM
emodo's Avatar
emodo
Cool
Hey Cougar41,just started it & everything is fine....?! I don't know what to think...
Old Jun 6, 2012 | 02:47 PM
Cougar41's Avatar
Cougar41
Is the ignition switch returning completely back to the run position when you let go after starting? If not, it may be cutting power to those effected systems.
