2010 caravan RKE battery replacement
Old Jun 7, 2012 | 03:53 PM
jamjma's Avatar
jamjma
Talking 2010 caravan RKE battery replacement
Is there any other way other than going to the dealer to get the remote to work for keyless entry after the battery is changed? I changed the battery now all the remote does is start the car.
Thanks in advance
Old Jun 20, 2012 | 07:13 PM
Tat-2's Avatar
Tat-2
Seriously??? You have to reprogram the remote after you change a battery.....
Old Jun 21, 2012 | 10:06 PM
georgef's Avatar
georgef
I found this on another forum:
ROLLING CODE
The rolling code feature changes part of the transmitter message each time that it is used. The transmitter message and the receiver message increment together. Under certain conditions with a rolling code system, such as pressing a button on the RKE transmitter over 255 times outside of receiver range or replacing the battery, the receiver and transmitter can fall out of synchronization. To re-synchronize, press and release the UNLOCK button on the RKE transmitter repeatedly (it may take up to eight cycles) while listening carefully for the power door locks in the vehicle to cycle, indicating that resynchronization has occurred.
The lock function works from the RKE transmitter even in an out of synchronization condition, therefore it could be verified by pressing the LOCK button on the RKE key fob.
George
