2009 GC Transmission wacko! Please help
Today, 40Miles from home, My transmission whacked out.
After driving there as normal, Heading home the gear indicator showed "D",but the trans wouldn't up shift. Appeared to maybe be in second. I limped it home on the backstreets.
I then shut it off and restarted it. It then seemed normal and shifted OK but maybe a little harsh. I'm freaked out.
Anybody got a clue ?
Thanks
John
Thanks
John
Ditto. No warranty? AutoZone will connect a scanner and read your codes for free. "Limp mode" is an actual term used to describe what you've experienced. The transmission control module in your engine computer detected a fault. It automatically shifted the transmission into second gear to keep you from further damaging the transmission. That left you with 1st, 2nd and reverse gears, just enough gear to get you to the nearest garage. The fact you were able to "reset" it points to an electrical failure of some sort.
Yeah, no warranty. 60K miles. I'll pull and clean the connector (s) There also appears to be some oil around the module. Valve cover isn't leaking so I'm not quite sure what to think about that. I've got a scanner so I'll hook that up and see if there's a code. The mil didn't come on however. More tomorrow.
Thanks
Thanks
