Infrared temp sensor replacement
I have a 2002 Grand Caravan with ATC. The infrared temperature sensor in the instrument panel has been physically damaged, resulting in the A/C blowing hot air unless the temperature is set to "LO".
I have disconnected and removed the sensor, but I'm wondering if it is possible to replace just this part? I don't want to have to replace the entire control system if possible.
