04 Caravan borges, like no pwer and shuts down
Old Jul 14, 2012 | 09:55 PM
undersiege's Avatar
undersiege
Default 04 Caravan borges, like no pwer and shuts down
I have a 04 stx caravan,had aproblem with the transmisson harness that goes to the pcm but had it repaired.Afterward the car would run fine once I increase speed slowly but if I tried to flow it it would borge and loose power. Now even while in park it will idle once started but will borge and shut off once you try to give it gas. I have no error codes. I also changed the plugs,any ideas what my problem could be?
Old Jul 15, 2012 | 09:31 PM
dsolorio's Avatar
dsolorio
Solenoid not engaging quick enough?
Old Jul 16, 2012 | 07:31 AM
undersiege's Avatar
undersiege
Your talking about the shift solenoid?
