08 caravan gets stuck in park
Old Jul 15, 2012 | 09:26 AM
mur007's Avatar
mur007
Default 08 caravan gets stuck in park
when i put the shifter in park the little square light that goes around the P R N D goes out and it will not come out of park.i then have to hope i can shake it till the light comes back on,then it will come out of park.it also does this when you go to move the shifter when it is in drive you can not put it into another gear with out pressing the button in. but now you can change the gears with out pressing the button.thats not right.brought the van in an the guy could not find anything. he did find a spring that was 1-3/4x1/4 he does not know where it came from.does anyone know how to fix this?and sorry i have a 3.3 in it and it is a 08 se
Old Jul 18, 2012 | 12:31 AM
lovvorn's Avatar
lovvorn
Default Pedal switch ?
Have someone look when you press the brake to see if the lights come on . You could have a bad switch or kicked out of adjustment by a big foot ? The relay will not operate if you have no lights . Lane
Old Jul 18, 2012 | 01:05 AM
steak59's Avatar
steak59
You probably need a shifter assembly, I've done a few in the dealer myself.
and yes, check the brake light. Also, there is a by pass button on top of the shifter stick that's cap off by a retangle cap.
Old Jul 19, 2012 | 10:03 PM
mur007's Avatar
mur007
i will try the shifter assembly..thanks for the help
Old Jul 22, 2012 | 05:40 PM
mur007's Avatar
mur007
Default got it to work
i did change to shifter assembly and that did nothing.then i adjusted the shifter cable at the transmission and it works fine for now thanks for your help
