Coolant ran into, stupid me.
Old Jul 22, 2012 | 07:16 PM
scotter5's Avatar
scotter5
Default Coolant ran into, stupid me.
3.8, 06
Changed timing cover gasket yesterday because I saw small drip coolant coming from bottom of timing cover, lost only about 6 ounces of coolant. Don't think any went into oil. Checked it. Drained oil anyway.
So I Put new oil in van. Put timing cover back, and everything else. Pressured it up and leak started again. PUlled it all off again. Lots of work again.
The gasket on timing cover had shifted while installing, careless me. Live and learn. Bad thing, coolant ran into oil since gasket had shifted when i installed. Another bad thing, I just put in new oil in van (20 bucks) and had to drain it because coolant went into oil since my gasket moved while installing. I drained it immediately without running the engine.
Hope everything is A-ok.
So
Old Jul 22, 2012 | 07:19 PM
RickMN's Avatar
RickMN
Welcome to the "Anything worth doing once is worth redoing" club. We've all been there.
Old Jul 22, 2012 | 08:09 PM
scotter5's Avatar
scotter5
thanks for the response and not a condemnation. i think i'lll change oil one more time to be certain. hate to pay another 20 bucks in addition to the HOAT i got to buy. Wish i could buy prestone for 1/2 of the price. maybe put some stp clean engine with the oil. thoughts. remember i didn't run engine with the coolant in the oil, if that makes a difference,which i believe it does.
thoughts????
Old Jul 23, 2012 | 11:45 AM
Hankster1's Avatar
Hankster1
just put water in for now and when you know it is leak free drain the water and put in the proper coolant.
Hank
Old Jul 23, 2012 | 03:07 PM
scotter5's Avatar
scotter5
Since you read my initial thread up top. coolant leaked into oil, because i screwed up when by moving the gasket on timing cover when installing. however i drained oil having the coolant in it immediatedly. then replaced with new oil. didn't run after that.
question: should i drain buy more oil again, thinking there maybe traces of coolant in somewhere. or something else? Thoughts??
