2003 caravan engine vibration and missing
Old Jul 27, 2012 | 06:13 PM
doylec's Avatar
doylec
Default 2003 caravan engine vibration and missing
my in laws have a 03 caravan with 21,000 miles, yes i know! last week engine started missing and vibrating, took it to the local dealer and they could find no problems. as luck would have it, it started doing it again. i was curious if the thermostat could be sticking? would the dealership had found this during their testing?
Old Jul 28, 2012 | 07:17 AM
papaduck's Avatar
papaduck
Mot likely that the thermostat is not at fault. Has the engine check light come on? You need to check it for codes. Could be a number of things, bad sparkplug wire, sticking injector or exhaust recerculation valve.
Old Jul 28, 2012 | 11:39 AM
doylec's Avatar
doylec
dealership said they pulled no codes. had tires balanced and rotated. seems to be doing this only at slow speeds.
Old Aug 11, 2012 | 01:38 PM
mrhoppers's Avatar
mrhoppers
I am having a similar problem except my 2003 3.3L caravan has 106,000 miles, trade? I have checked wiring harnesses, cleaned the throttle body, and replaced the coil pack as I did have a code indicating a coil pack issue. Mine started after having the spark plugs, wires, and water pump replaced. Did you ever resolve this?
