2004 Dodge Caravan, Tail Lights not working?
Old Aug 15, 2012 | 07:50 PM
jeff04dodge's Avatar
jeff04dodge
Default 2004 Dodge Caravan, Tail Lights not working?
Hey guys I have a problem, My tail lights are not working.
All the other lights work fine (break, head, turn signals) but at night when I turn on the lights the tail lights are not working.
Its a 2004 model, what could be the issue and how do I fix it?
Thanks for any help.
Old Aug 15, 2012 | 08:55 PM
hatemyvan's Avatar
hatemyvan
I would start with the obvious, check the bulbs and fuse, also check the general condition of the connector making sure there is no corrosion. The lenses are known for separating from the rest of the assembly allowing water to enter which can corrode the connector. I had a similar problem with my van tail lights and mice had chewed the wires underneath the fuse block in the engine bay by the battery. Hope this at least gives you somewhere to start.
Old Aug 15, 2012 | 11:33 PM
Cougar41's Avatar
Cougar41
Front parking lights work correct? Fuse? No. There are two. One powers the left side fore and aft the other the right side fore and aft. Fronts are working so can't be a fuse. Parking light relay? No. Single output powers all for corners. That leaves the Front Control Module (FCM) and the IPM - your fuse box. The FCM controls power to all the exterior lights. The IPM routes power from the FCM to the respective light circuits. Both have a known issue with corrosion. Try a wiggle test on IPM and it's connectors and see if the lights try to come on. No joy? Loosen up the bolts on the FCM on the front of the IPM and try wiggling it. Still no lights? Remove the IPM connections and the FCM and inspect for damaged/corroded contacts. Make sure you disconnect the negative battery cable first.
Old Sep 17, 2012 | 10:41 AM
jeffb1941@yahoo.com's Avatar
jeffb1941@yahoo.com
where is the fcm
Old Sep 17, 2012 | 03:41 PM
Cougar41's Avatar
Cougar41
Originally Posted by jeffb1941@yahoo.com
where is the fcm
It's that silver box bolted to the front of the IPM (fuse box).
Old Apr 14, 2013 | 02:49 AM
JoseSolis's Avatar
JoseSolis
Default mr
I have a dodge caravan and I want install a remote starter but I need to know if has a (-) negative parking light output or works whit (+)
Old Apr 14, 2013 | 02:55 AM
JoseSolis's Avatar
JoseSolis
I have a dodge caravan 1998 and I want to install remote starter and I want to know if has a (-) negative parking light output or(+)
