I need alarm or key help ASAP!! 2006 Caravan!
Old Aug 20, 2012 | 06:41 PM
mikerolo's Avatar
mikerolo
Default I need alarm or key help ASAP!! 2006 Caravan!
Ok, ..2006 caravan... Today I hit the unlock button on my key and the alarm went off! now I cant get it to stop. Tried drive door lock, tried turning the key, tried other key I have wont turn it off, I have a valet switch but not sure how to use it, tried disconnecting the battery for a bit...nothing is working. If I get in the car and start it the alarm will time out good thing so I could get home from work, but as soon as I open the door alarm goes off again? If anyone has a fix it would be greatly appreciated.
Old Aug 20, 2012 | 11:36 PM
steak59's Avatar
steak59
Factory alarm or aftermarket?
Old Aug 21, 2012 | 08:56 AM
mikerolo's Avatar
mikerolo
Default pretty sure its stock
Old Aug 21, 2012 | 12:42 PM
Tizzy1's Avatar
Tizzy1
If you have a valet switch, it is not factory, could be dealer installed or aftermarket. Should be a module up under the dash by the column somewhere. Need to see if it's a Mopar system or not. Mopar's system is labeled EVS.
