99 Grand Caravan wiring problem
Old Aug 29, 2005 | 09:17 PM
tjon's Avatar
tjon
Default 99 Grand Caravan wiring problem
My 99 Grand caravan's left running light (it's a Canadian model) and turn signal don't work. Replaced the flasher and lamp but still the same. Does anybody have a wiring diagram?
Old Aug 30, 2005 | 01:35 AM
brandoncrone's Avatar
brandoncrone
Default RE: 99 Grand Caravan wiring problem
Did you check the daytime running light module???? Its inside at the rh side of the fuse panel. The DRLs use the turn signal filament for the DRLs
Old Aug 30, 2005 | 01:23 PM
tjon's Avatar
tjon
Is the daytime running light module about twice as wide as the other relays, etc., in the fuse panel? If so I swapped it with a buddy's and it didn't help. Thanks anyhow.
