Brake booster replacement/adjustment
Old Oct 10, 2012 | 06:53 PM
98PVOYA's Avatar
98PVOYA
Default Brake booster replacement/adjustment
98 Voyager 3.3L
Hi! I replaced the brake booster (squeling and hissing) but when I connected the battery, the brake tail light is on. Is there any adjustment of the brake or the booster?
I searced but can't find any procedure except an occasional mention of adjustment (?).
Thanks for your help.
r/Gerry
Old Oct 11, 2012 | 10:22 AM
98PVOYA's Avatar
98PVOYA
Solution:
After a lot of reading, the brake light switch (white thing connected to a electrical wire)plunger must be pull all the way out before installation. This is the swicth that is connected to the bracket near the pedal arm. When the brake pedal is push the plunger push out and turn the brake light. This switch is also cut the cruise control when the pedal is push.
