Spark plug problem
Old Oct 15, 2012 | 12:22 AM
zoomie36's Avatar
zoomie36
New Member
Default Spark plug problem
Wierd problem. I replaced all my spark plugs on my 2005 caravan 3.3l with Champion plugs, last year. I have now had to replace 2 of them because they malfunction. I came up with fault code 0306 (misfire #6 cylinder) for the last spark plug, but can't remember which was the first spark plug to go bad. The engine starts to hesitate a little, then really miss, then check engine light....a new spark plug cures it.
Can it really be a bad batch of champion spark plugs or is something happening with the electronic igntion system to damage the plugs????
Thanks for any replys....
Old Oct 15, 2012 | 05:05 AM
papaduck's Avatar
papaduck
Did you make sure the gap was correct before installing the plugs? It is possible that you got some plugs that were prone to fail, I have in times past.
