Rim question (2012 Caravan)
Old Oct 30, 2012 | 06:18 PM
bosssman's Avatar
bosssman
Default Rim question (2012 Caravan)
So I've been looking at buying a set of 16" rims to put my summer tires on and then put winters on the steel rims.
Any 16" rims from other Dodge's fit the 2012 Grand Caravan ? I heard the Journey rims fit but the local dealer says no.
As you call know bolt pattern 5x127
Old Nov 4, 2012 | 10:04 PM
sbestca's Avatar
sbestca
or 5 x 5" and a 71mm hub with a 20mm offset.
Also remember that you should have Tire Pressure Monitor System TPSM sensors mounted on each rim for a purchase cost of $65 each.
I ordered an $80 set of 4 sensors off Ebay, we will see what I get.
Still looking for winter rims myself.
Any problem with running 215/70R16 winter tires instead of the 225/65R16?
Old Nov 5, 2012 | 08:20 AM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
5 lug 5 inch or 127mm High Positive Offset
H = High Positive or FWD (Front Wheel Drive) typically +45, 40, 35 offsets
71.5" hub.
this is atleast on the 17" wheels set on my 2010 sxt
20 offset sounds not right? might be ok for 16" vehicles though
Old Nov 20, 2012 | 09:27 PM
Joshg1983's Avatar
Joshg1983
I have a set of 16" steel wheels and journey hub caps, I purchased them separate, wheels ARE from a 2010 T&C, however if your van has dual piston front brake calipers, as my R/T does, these wheels will not work. As this is why i am selling.
Old Nov 21, 2012 | 07:08 AM
sbestca's Avatar
sbestca
215/70R16 Michelin winter tires worked well instead of the 225/65R16 stock size.
The $80 ebay sensors work fine, and bought steel rims from dealer for $288.
