Oem mopar keyless entry module
Old Nov 1, 2012 | 06:39 PM
blaqyukon's Avatar
blaqyukon
Default Oem mopar keyless entry module
i have a 2001 grand caravan and it got stolen i have an alarm but i didnt
get a chance to install it yet because i researched and found that the caravan wiring you need to use resistors to shunt out the triggers for the
doors and you have to go into the BCM= body control module, looking for
wires, and using diodes to block or isolate the other door triggers because they are installed on the same lock/unlock leads, anyway i found the original
keyless module (04883257) that i guess came with the caravan, does any one
where i can find the key fobs and a wiring diagram for this module, so i can some protection untill i get all the things i need to put my new keyless alarm in. the factory is lame but then the guys that stole the caravan where lame also because they dont know how to pull an ignition with out tearing up the housing they need to find a new line of work. the idiot in nyc see a flashing lite and they will back off. i search the web and nothing turned up yet..
