Front Heater Not Blowing
Old Nov 13, 2012 | 02:32 PM
nickspeckin's Avatar
nickspeckin
Default Front Heater Not Blowing
I have a 2002 Caravan.The heater only blows SOMETIMES.I replaced the blower motor resistor.Sometimes when I start the van it turns on,sometimes after the van is running for 5 to 10 min. it starts,sometimes it doesn't start.When I push the power button i hear a small "click"and a short "bzzzzz" where the blower motor is but it doesn't come on.When I turn it off I hear the same thing.Could this be a relay or is it possiblt the blower motor?
Old Nov 13, 2012 | 03:35 PM
Tizzy1's Avatar
Tizzy1
hit the blowe motor a couple of times and see if it starts working.
Old Nov 13, 2012 | 05:06 PM
nickspeckin
Default Blower
Last night when I hit the dash around where the blower is located it did kick on.I don't know if this was coincedence.When I just started it the blower came on.Soumeone just told me they think its the blower motor.I don't know what that "click-BZZZZ" is unless its the fan trying to start.Could it possibly be a relay?
Old Nov 13, 2012 | 07:09 PM
Cougar41's Avatar
Cougar41
The relay is in the fuse box (IPM) under the hood. Not sure you'd be able to hear it. Try swapping it with an identical relay on the panel.
Old Nov 14, 2012 | 08:37 AM
grswat's Avatar
grswat
Its the motor.
Old Nov 14, 2012 | 04:47 PM
Cougar41's Avatar
Cougar41
Yup, probably the motor or a loose connection under the dash. Taking three minutes to swap a $10 relay with another next to it will eliminate a stated concern of the OP. It's that piece of mind thing that helps one sleep at night.
Old Nov 17, 2012 | 02:48 PM
ShowBiz's Avatar
ShowBiz
Thumbs up Blower relay, resistor and motor
Once again DF has saved the day for me. I too had the blower poop out on me. I did my homework here and decided to try replacing the relay first and if that didn't work I'd replace the resistor. Success with replacing the resistor. I have a feeling that the motor will eventually need replacing as well.
Of note: I researched the various brands of resistors and customer reviews
indicated that these new resistors (boy do they look different from the original)
have a tendancy to fail. Customers had to get replacements up to three times before getting one that was good.
I'm just so tickled that I could save so much time and money by doing all this
myself. Piece of cake. My girl friends want me to come fix their cars now.
Thanks DF!!!
ShowB1z
...have dogs, will show...
Old Nov 17, 2012 | 04:12 PM
b1lk1's Avatar
b1lk1
9 times out of 10 if the resistor fails, it is due to the blower motor getting ready to fail.
Old Nov 19, 2012 | 05:29 PM
Tizzy1's Avatar
Tizzy1
Amen b1!!
Old Nov 20, 2012 | 12:10 AM
shadoro's Avatar
shadoro
Default blower motor
Did you have the windshield replaced on the van? If you did, they take a piece of weather stripping off the top of the wiper cowling were it meets the windshield and it allows water to run down inside the firewall through the plenum and finally down into the blower motor causing it to fail. That is what happened with my 2001 grand caravan. Hope this helps.
