99 Grand Caravan SE w/3.3L timing cover gasket change
Old Nov 21, 2012 | 08:45 AM
lanceb's Avatar
lanceb
Default 99 Grand Caravan SE w/3.3L timing cover gasket change
I am about to do a timing cover gasket change on our caravan and I see in bold print in the factory manual DO NOT USE SEALANT ON GASKET. Can anybody tell me why? I usually use RTV when dealing with water components. What's the problem with using it? Or, is there something else I should be using?
Old Nov 22, 2012 | 05:58 AM
grswat's Avatar
grswat
I used sealant when I changed it on an 04. Use sparingly so chunks of it don't get inside the motor.
Old Nov 22, 2012 | 03:32 PM
ryan42's Avatar
ryan42
In trying to apply a thin layer of sealant, I have found this to be very helpful:
Amazon Amazon
(I think I picked up mine at Autozone, though.)
You can lay the gasket over some cardboard and coat both sides with a thin layer that's enough to hold the gasket to the part during assembly and help seal, but not so much that it goops out the edges when bolting it down.
I'm not sure what the reasoning is behind the not using a sealant for the gasket, but if over-use/clumps of RTV is the concern, spray sealant might be very helpful.
There might be some other reason though, I don't know.
Old Nov 25, 2012 | 08:35 PM
lanceb's Avatar
lanceb
Thanks for the responses. I used black RTV and so far everything is good. I let the RTV set up overnight before re-filling with antifreeze. Looks like I might have a rear main seal leak. The transmission bell housing has oil in it.
