MikeMan65 |
11-25-2012 07:49 PM |
MikeMan65
Just Installed 6 new fuel injectors (Code on #3 injector control - wiring seems OK). Not easy. Had to remove the air plenum, Throttle body, egr, and egr pipe to manifold. Disconnected the map sensor and removed the Vacuum lines that where not broken. Reinstalled everything. Replaced the broken Vacuum lines that I could see. But still don't know where the EGR Vacuum was connected. So I hooked it to the Manifold tree using a blocked off port (per the vacuum diagram). Had a hard time starting the engine, but it finally fired. Would idle, not No Throttle, ran real rough. Disconnected the Map sensor and got throttle, up to about 2000+ rpm, smooth running (a lot of smoke initially - no code on fuel injectors). Released the throttle and it died. Restarted, idled at about 1100 rpm (sounded good). Reconnected the MAP Sensor, idle dropped to about 800 rpm, and ran rough, but this time I had some throttle (not much). Do I have a bad MAP Sensor or a vacuum leak from where the EGR originally vacuum source (Where ever that was). It's not throwing any codes, can anybody help?:icon_smash:
