Speedometer Needle points down -- Epoxy or Glue for...
Old Nov 29, 2012 | 02:05 PM
quantass's Avatar
quantass
Question Speedometer Needle points down -- Epoxy or Glue for...
I removed my Instrument Cluster and i accidentally broke the small black stick which restricts the speedometer needle from pointing to the ground. The needle is fine though. I am worried when i reinstall the needle will be way off and so would like the needle positioned back over the lowest # (20km).
What adhesive would you recommend for this small stick so that i may attach it back to its flat base? The stick's flat bottom is quite tiny. After attaching it i dont want to worry about it falling off once i reinstall the cluster. I was considering a screw right thru the area.
Old Nov 29, 2012 | 03:02 PM
Tizzy1's Avatar
Tizzy1
you could stick anything you want on there, just as long as it is tall enough to hold the needle.
Old Nov 29, 2012 | 09:52 PM
quantass's Avatar
quantass
Much appreciated. Instead i purchased some plastic adhesive and it did the trick.
Thanks so much
