90 caravan driver cv axel
Old Sep 7, 2005 | 02:57 PM
mufasa's Avatar
mufasa
Default 90 caravan driver cv axel
This is the second time in 6 months i have broke the driver side drive axel is there something i should look for that would be the cause of this happening?
90 caravan se
3.0
power everything
Old Sep 15, 2005 | 12:44 AM
hemipower1984's Avatar
hemipower1984
Default RE: 90 caravan driver cv axel
if it broke at the cv joint the boot was probably ripped open. if the shaft itself broke then this is because the rubber isolator on the shaft actually holds water on the shaft causing it to wear down and break the shaft. you just need to replace the shaft . reman shaft $100.00 approx.
