drivers side power window problem
Old Dec 9, 2012 | 09:55 AM
DonMtl.'s Avatar
DonMtl.
Default drivers side power window problem
2010 Grand Caravan 47,000 km. the driver's power window will open only about 4-5 inches, closes fine, it just won't go down even if I try to push it a bit...no strange noises. All other windows operate normally.
Don
Old Dec 10, 2012 | 10:25 AM
Tizzy1's Avatar
Tizzy1
Could be a glass run weatherstrip issue. Sometime the weatherstrip isn't seated properly in the channel or is tight and wears through to the rubber causing the glass to bind.
Old Dec 12, 2012 | 05:27 PM
DonMtl.'s Avatar
DonMtl.
Didn't have time to do anything about this...then today it just opens normally !
It won't "auto-up" though...it does auto-down...I guess it is the switch...again !
Old Dec 12, 2012 | 11:18 PM
steak59's Avatar
steak59
Wait, so you mean the AUTO down feature would only go down 5 inch? or you mean the window gets Stuck at 5 inch?
If you meant the problem is the Auto Feature, then you just need to relearn the position by Holding the DOWN button for like 10 second, and then UP button for 10 second.
Old Dec 13, 2012 | 06:50 AM
DonMtl.'s Avatar
DonMtl.
Red face
Thanks Steak59,
All is now back to normal !
Old Dec 13, 2012 | 11:04 AM
Tizzy1's Avatar
Tizzy1
LOL.........guess I shouldn't assume
