02 dodge caravan 3.3 help,
I have check engine light on, so i took it to autozone and thay gave me these codes
P0171
P0442
Idk what it could be,
But thw minivan runs fine,
And when i came home i stayed home all day and today in the morning i tried to go out and it wouldnt start like if it wasnt receiving gas so i pressed on the gas and cranked it up and it cranked up, then after 4mins it started right up, i also checked and found some kind of smoke in the floor which is dirt floor so it was like a powder, its black, every time it starts it spits that powdee thing, also when its on and i accelerate when it reaches like 5rpm's
It like jumps acelerating i dnt know how to explain it, it like skips while acelerating
P0171
P0442
P0171-FUEL SYSTEM 1/1 LEAN
P0442-EVAP SYSTEM MEDIUM LEAK
Cant help you with the cause or next step, & see code info in the 2nd Sticky.
G-Luck.P0171 Fuel System Lean Bank 1/1
Possible Causes
PCM
Possible Causes
INTERMITTENT CONDITION
RESTRICTED FUEL SUPPLY LINE
FUEL PUMP INLET STRAINER PLUGGED
FUEL PUMP MODULE
O2 SENSOR
O2 SENSOR SIGNAL CIRCUIT SHORTED TO GROUND
O2 SENSOR HEATER OPERATION
TPS VOLTAGE GREATER THAN 0.92 VOLTS WITH THROTTLE CLOSED
THROTTLE POSITION SENSOR SWEEP
MAP SENSOR OPERATION
ECT SENSOR OPERATION
ENGINE MECHANICAL PROBLEM
FUEL FILTER/PRESSURE REGULATOR (HIGH)
FUEL PUMP MODULE
O2 SENSOR
PCM
