08 Dodge Grand Caravan A/C Compressor and Radiator Fan not working
Old Jan 19, 2013 | 09:42 PM
cgwiley's Avatar
cgwiley
Default 08 Dodge Grand Caravan A/C Compressor and Radiator Fan not working
Both the A/C Compressor and Radiator Fan stopped working at the same time. I jumped the fan to the battery and it works fine. I also check all the fuses. I was talking to a mechanic and he thinks it might be a heat sensor. Anyone have any idea's as to what the issue could be?
Thank you for all the help,
Chad
Old Jan 19, 2013 | 11:56 PM
go-part's Avatar
go-part
Former Vendor
Well the ac compressor does work in tandem with the radiator fan.
Check the fuses and relay, then if they are ok you should look into a new temperature sensor.
