Undetermined Oil Leak
Old Jan 24, 2013 | 02:46 AM
mosco28's Avatar
mosco28
Default Undetermined Oil Leak
I discovered that my Van has an Oil leak just beside the Passenger side wheel.
Its a reddish, Light brown color and it feels greasy. Now a day or two before the Van made a horrible Grinding/screaming noise in the same location near the belts, and it stoped 5 seconds later. I checked it out and did not see anything loose or distressed.
3.3L 2005 Dodge Grand Caravan,
Old Jan 24, 2013 | 03:31 AM
papaduck's Avatar
papaduck
The power steering pump may be failing. The power steering uses ATF+4 which is red.
Old Jan 24, 2013 | 06:11 AM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
if power steering squeeling replace the oil resovour. theres a fine mesh filter in it that if plugs cause the pump squeel.
Old Jan 24, 2013 | 11:03 AM
steak59's Avatar
steak59
Possible a leaking water pump too, Coolants are red.
But like the others said, could be power steering pump. Inspect if powersteering fluid and coolant for being low.
