'96 Caravan 3.3
Old Jan 29, 2013 | 01:10 AM
easttxcaravan's Avatar
easttxcaravan
Default '96 Caravan 3.3
Engine making howling noise. All fluids are full, have checked PS pump, does not appear to be from it, and water pump has been replaced. Vehicle doesn't overheat, and no problems turning steering wheel. What else can I check on this?
Old Jan 29, 2013 | 03:09 PM
Tizzy1's Avatar
Tizzy1
Could be a tensioner pulley bearing or idler pulley bearing.
Old Jan 29, 2013 | 06:24 PM
Cougar41's Avatar
Cougar41
Remove the serpentine belt and start it up. If the noise is gone you know it's something the belt drives such as Tizzy1's suggestion.
Old Feb 5, 2013 | 01:13 AM
easttxcaravan
Thanks. I'll give it a try. Will post if I figure it out correctly.
