Alternate tire sizes for an 09 Caravan?
Old Feb 4, 2013 | 12:00 PM
Daleford's Avatar
Daleford
Default Alternate tire sizes for an 09 Caravan?
I have unpopular size tires on an 09 Grand Caravan. Chrysler calls for a 225-65-16 and it is a hard to find size. Where I live Walmart can't supply it. I started asking around for info on an alternate size that would work. I understand with high tech suspensions and computers you don't want to go too far astray, but.....I'm thinking a more popular size is going to be less expensive.
Anyone have info on what sizes would work and not cause any problems?
Old Feb 4, 2013 | 07:16 PM
DGCaravan's Avatar
DGCaravan
Any Dodge dealership will have 225-65-16 in stock. You can also try Tirerack. They usually have a good selection. Their prices start $94 a tire.
http://www.tirerack.com/tires/TireSe...tpackage=false
You can also go with 17 rims 225/65-17. You may have a better luck finding this size. The dealership can adjust your speedometer if you go with the 17s.
Old Feb 4, 2013 | 07:36 PM
Daleford's Avatar
Daleford
Thanks. I don't have easy access to Tire Rack [I am in Canada] and the Dodge dealership has kinda high prices. WalMart has a Firestone that will do but not in my size. They do have a 235 65 16 that would be approx 1/2 inch greater in diameter. Is that OK?
Old Feb 4, 2013 | 10:19 PM
DGCaravan's Avatar
DGCaravan
The 235 65 16 should work. Just keep in mind that when your speedometer reads 70 mph, you're traveling at 68.72 mph.
Optional/Plus Sizes using Discounttire.com
Plus Zero
215/70-16
235/60-16
235/65-16
255/60-16
