97 Caravan Electrical problem
Old Sep 13, 2005 | 01:13 PM
myt69mopar's Avatar
myt69mopar
Default 97 Caravan Electrical problem
Help me please,
I have a 97 Caravan with a toublesome electrical problem and I don't know where to start. The problem goes like this; Horn doesn't work, Air Bag lamp is on, A/C clutch runs whenever the heatet fan is turned on and every now and then the wipers go up and down once by themselves. If anyone can point me in some direction I would greatly appreciate it. The only thing I've tried was replacing the fuse and relay center under the hood, but needless to say that didn't work. HELP PLEASE!!!!!
Old Sep 14, 2005 | 01:21 AM
tenntech's Avatar
tenntech
Default RE: 97 Caravan Electrical problem
The airbag light and the horn are probably your clockspring. This problem is covered by the B24 clockspring recall. As far as the compressor running while on heat, this may be normal depending on the mode setting. Most vehicles will cycle the compressor while on defrost and sometimes on other settings. The wipers are probably a wiring problem or possibly a relay, but most likely not related to your other problems.
Old Sep 14, 2005 | 09:05 AM
Toecutter's Avatar
Toecutter
ORIGINAL: tenntech
Mr. TennTech,
Could you go further into this "Recall" you mentioned about?
TY,
Toe
Old Sep 14, 2005 | 04:44 PM
myt69mopar's Avatar
myt69mopar
Tenntech,
Thanks a bunch. I called Daimler/Chrysler and that recall is an outstanding recall on my van and they are the symptoms. i'll check into the other two but thanks for shedding some new light on them. Your assistance is VERY much appreciated.
Old Sep 14, 2005 | 04:57 PM
601dodge's Avatar
601dodge
Default HEY I GOT ONE FOR YA
JUST BOUGHT A 98 CARAVAN FOR A LITTLE BIT OF NOTHING. HOW DO YOU KNOW WHEN THE AC NEEDS RECHARGING OR IF THE WHOLE AC COMPRESSOR IS GONE. AND THEN A LITTLE SOMETHING THAT KINDA BLEW MY MIND. WHEN I WAS DRIVING FOR ABOUT 30 MINUTES THE LITTLE INSTRUMENT CLUSTER THAT HOLDS THE HEADLIGTS AND INTERIOR LIGHT SWITCHES STARTED SMOKING. IS THIS AN ELECTRICAL PROBLEM OR JUST THE SWITCH GONE BAD. HOW MUCH WOULD A NEW ONE COST ME.
Old Sep 16, 2005 | 12:30 AM
tenntech's Avatar
tenntech
Mr. TennTech,
TY,
Toe
This recall is a B24 clockspring recall. If the van is under 75,000 mi. the clockspring gets replaced, if it is over 75,000 mi. you only replace it if it has failed. This is a lifetime warranty, so even if the component fails after the recall has been done you can have the clockspring replaced as many times as it fails.
