Front drivers side window closes intermittently
Old Sep 14, 2005 | 04:03 PM
BigBadBen's Avatar
BigBadBen
Default Front drivers side window closes intermittently
Once you cycle the ignition on and off all is OK again...any ideas guys'? My wife presses the switch to raise the window and it stops anywhere going up and then stops. This only happens when raising the window.
Cheers,
Ben
Old Sep 15, 2005 | 12:33 AM
hemipower1984's Avatar
hemipower1984
Default RE: Front drivers side window closes intermittently
this is the window motor binding you will need to replace regulator assembly.
Old Sep 15, 2005 | 01:17 PM
BigBadBen's Avatar
BigBadBen
Cheers hemipower...I really appreciate the diagnosis...
Old Sep 16, 2005 | 03:21 PM
nmlhaus's Avatar
nmlhaus
Maybe regulator, but another possibility, happened to me on my 94. Two wires in the harness that comes into the driver's side door had been damaged. The symptom started as passengers window would not go up, but would come down, then got worse, wouldn't come down sometimes. My wife's friend discovered that if one person held the driver's door open appx half-way, the up button on the passenger's side would work, and if you held the driver's door 3/4 of the way open, the passenger's down button would work. I razor-bladed open the rubber shrouding, found the wires (one had broken all the way through), repaired them, wiretied the shrouding back together, and good as gold, except for looking a little messy. Just a thought from my own experiences
Old Jun 19, 2006 | 11:41 AM
sunflower's Avatar
sunflower
How do you remove the inside door panels?? Do they just pull off after you remove the 2 screws in panel ?? Help.Drivers window went 1/2 way up and has'nt moved again.
