Where is this mount located?
Old Mar 2, 2013 | 09:16 PM
sniper82's Avatar
sniper82
Default Where is this mount located?
I have a 02 GC Sport with 3.3 and it has a slight jerk from 1st to 2nd and sometimes when downshifting in that those gears. I haven't had it long so I've never been under it. I am hoping its a mount issue and not something with the transmission. I know the front left is bad because the rubber has separated and is sagging down. But I can't seem to locate this mount to see if its bad:
http://cdn1.autopartsnetwork.com/ima...1857324MPR.JPG
I think its call the rear left but I am not sure. Could these mounts being bad cause the shifting symptoms?
Old Mar 2, 2013 | 10:22 PM
aofarrell2's Avatar
aofarrell2
What are your RPMs when it downshifts and upshifts between 1st and 2nd? Usually these vans start in 2nd.
Old Mar 5, 2013 | 03:32 PM
sniper82's Avatar
sniper82
I'll have to report back on that one. As for this mount I am going to assume no one knows where this mount is located or is it for a different year? Or maybe it can't be seen from above the car?
Old Mar 5, 2013 | 04:28 PM
Tizzy1's Avatar
Tizzy1
That is the rear mount, it goes back on top of where the rack and pinion is on the craddle
