2006 Grand Caravan Stalls after getting gas
Old Mar 14, 2013 | 10:57 PM
rjg202's Avatar
rjg202
Default 2006 Grand Caravan Stalls after getting gas
After filling up, our 3.8 L sputters/stalls for a second or 2. Wondering if it is a check valve or Canister. I have Lifetime power train warranty, not sure if something like this would be covered or not. It only does it once, then ok til next fill up. This just started recently and we don't squeeze gas in when pump shuts off.
Thanks
Old Mar 15, 2013 | 12:25 AM
steak59's Avatar
steak59
is the CEL on?
Old Mar 15, 2013 | 04:17 AM
papaduck's Avatar
papaduck
The vapor canister is purged after filling and instead of vapor, liquid gas is injected into the engine, making the fuel mixture too rich causing the engine to stumble or even die.
Mine does this and the fix is too expensive, so I just live with it. If you can shut the pump off before the tank is full you can avoid this problem.
Old Mar 15, 2013 | 09:13 AM
rjg202's Avatar
rjg202
Originally Posted by steak59
is the CEL on?
No, Check Engine Lights are on. It passed emissions a few weeks back. It is just an annoyance. I saw the other comment about shutting off before filled, I will mention that to her as well.
Old Mar 16, 2013 | 01:40 AM
steak59's Avatar
steak59
yeah... you might need a gas tank. Some of the check valve is probably bad and allowing Raw fuel to enter the Canister.
I guess you'll just have to work around it and only fill up to 3/4 tank everytime.
Old Mar 16, 2013 | 11:48 AM
Montreal300's Avatar
Montreal300
Same problem with early 300's as well. In this case the tanks were revised for the late 2006/2007 year. It's an expensive fix totaling $1,600.
