1995 Dodge Caravan Wiring Issue
Old Mar 16, 2013 | 04:47 PM
redbull6679's Avatar
redbull6679
Default 1995 Dodge Caravan Wiring Issue
I bought a 1995 Dodge Caravan with 3.0L. The dome lights and radio don't work but everything else does. I have checked all of the obvious fuses and they are good. The radio would pop when you turned it on and then nothing. No lights or sound, so I thought bad radio. When I was wiring in a new radio I was testing the wiring and I only have power when the ignition is on. I have a haynes manual but the wiring diagram leaves a little bit to be desired. Does anybody know if the dome lights and radio are inter-related? Do they share a relay? Does anybody know where I can get a better wiring diagram so I can trace the battery wire from the radio all the way back to the battery?
Old Mar 16, 2013 | 11:30 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Alldata. Haynes books are good for campfire starter.
