engine noise
Old Mar 30, 2013 | 08:19 AM
cappo's Avatar
cappo
Default engine noise
my '03 Caravan has had an engine rattle for quite some time now. only hear it at idle. Has the 3.3 litre Flex fuel engine. so I took the serpentine belt off and ran it and did not hear the noise. I hand-turned each pulley and only the power steering pump may have had a little play in it. However when I put the belt back on there was no noise for about 3 hrs driving and then the noise re-appeared. any help is appreciated
Old Mar 30, 2013 | 03:10 PM
papaduck's Avatar
papaduck
Use a stethescope or a piece of hose and listen to each item driven by the belt. Be very careful and do not get tangled with the belt.
Old Mar 30, 2013 | 03:32 PM
cappo's Avatar
cappo
thanks papaduck, can I rule out the timing chain since the noise went away temporarily?
