2002 caravan has air only on driver's side and rear
Subscribe
Apr 10, 2013 | 01:06 PM
apparently the blend door is not closing on passenger side so we have a/c only on driver and rear. I can see that the door is not closing but I have no idea how to fix it.
Reply 0
Apr 10, 2013 | 03:09 PM
Welcome to the forum. Stupid question, how do you know the door isn't moving? Maybe a simple system calibration will fix your issue. Can't hurt anyway.
STANDARD PROCEDURE - HEATER-A/C CONTROL CALIBRATION
The heater-A/C control module must be recalibrated each time an actuator motor or the control module is replaced. If the vehicle is so equipped, the calibration procedure also includes rear HVAC positions for each actuator motor.
Turn the ignition switch to the On position.
Simultaneously depress and hold the Power and Recirculation buttons on the heater-A/C control for at least five seconds. The manual heater-A/C control power Light Emitting Diode (LED) and Recirculation LED, or the Automatic Temperature Control (ATC) heater-A/C control Delay and Recirculation graphics will begin to flash when the calibration procedure has begun.
The calibration procedure should take less than two minutes to complete for the manual heater-A/C control, and less than twenty seconds for the ATC heater-A/C control. When the LEDs or graphics stop flashing, the calibration procedure is complete.
If the LEDs or graphics continue to flash beyond the normal three minute (manual) or twenty second (ATC) calibration time, it indicates that the heater-A/C control has detected a failure and a Diagnostic Trouble Code (DTC) has been set. Use a DRBIIIŽ scan tool to perform further diagnosis. Refer to the appropriate diagnostic information. The LEDs or graphics will continue to flash even after the ignition switch is cycled Off and On, until a successful calibration is completed or until the vehicle has been driven about 13 kilometers (8 miles).
Reply 0
Subscribe
