AC compressor not working, no cool air
Old Apr 14, 2013 | 11:22 AM
ledvedder's Avatar
ledvedder
Default AC compressor not working, no cool air
I tried my AC a few days ago on my 2003 Caravan, and the air is not getting cool. I don't hear the compressor coming on. Last year, the refrigerant was low, so I charged it, and it worked fine for the rest of the summer. Now, I get nothing but warm air. What should I check for?
Old Apr 14, 2013 | 04:57 PM
steak59's Avatar
steak59
Check Freon level. Maybe you got a leak somewhere, and it leaked out over the winter.
Old Apr 14, 2013 | 10:08 PM
Town's Avatar
Town
If you put a dye in the A/C system when you charged it then a black light will show the traces of dye from the leak. If not then put the dye in when you re-charge the system so you will find the leak easily next time.
Good luck.
Old Apr 15, 2013 | 10:42 AM
ledvedder's Avatar
ledvedder
I checked the pressure and it was zero. I was able to get it up to 25 psi, by adding 3 cans of freon. The compressor is now coming on. I guess I have a leak somewhere. I added some red dye, but was unable to detect any leaks from where I could see. Any suggestions about where to check for leaks?
Old Apr 15, 2013 | 02:54 PM
Cougar41's Avatar
Cougar41
The evaporator under the dash or in the rear is the usual culprit if you don't see leaks elsewhere. The Condenser in front of the radiator takes a lot of punishment.
Old Apr 15, 2013 | 03:10 PM
ledvedder's Avatar
ledvedder
This stuff is probably beyond my knowledge. Looks like I may have to take it to a shop and prepare for a raping!
