08 Dodge Grand Caravan
Old May 6, 2013 | 10:09 PM
theark's Avatar
theark
Default 08 Dodge Grand Caravan
my lock button on driver side stoped working and on the same time when I press the unlock button it locks any help locating the relay or how I can fix it is appreciated thank you
Old May 7, 2013 | 10:33 AM
kuyabribri's Avatar
kuyabribri
Quick check: Do the lock buttons on the passenger side do the same thing? If the passenger side works normally I'd suspect the driver side switch itself has gone bad, not a relay.
Old May 8, 2013 | 07:50 AM
theark's Avatar
theark
thanks and yes the passenger side works good
I will try to replace the buttons thank you so much hope that helps
