2009 Caravan, hose leaks behind 'dist cap'
Old May 11, 2013 | 02:56 AM
Mac Bentley's Avatar
Mac Bentley
Default 2009 Caravan, hose leaks behind 'dist cap'
There's a leak from an 'accordian' type hose where it attaches to a metal pipe coming under the 'distributor cap' from the rear. The other end of the hose appears to attach to a metal (aluminum?) pipe that crosses over to the passenger side near the firewall. I'm not good with smells, but it seems like coolant. Drips more than once a second. Hopefully you can see the black stream in the photo. This is my first attempt at a post.
Old May 11, 2013 | 08:05 AM
Lscman's Avatar
Lscman
There's at least a half dozen excellent threads about it. The plastic y-pipe fails, so most folks replace it with metal piping. Don't drive it with low fluid or you may turn a $50 repair job into a $1200 head gasket failure.
Old May 11, 2013 | 08:37 AM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
YEP famous plastic Y. try getting a brass wye. little hard to find but probably works better.
Old May 11, 2013 | 09:29 AM
Mac Bentley
Lscman, when you say fluid, are you talking about coolant? What's the purpose of this y-pipe?
Thanks.
Old May 11, 2013 | 09:45 AM
Lscman's Avatar
Lscman
Thanks.
I can't regurgitate the content of the other threads because they are many pages long and why? It would be best to find and read them via search. I would also suggest finding the youtube videos about this topic. I found all them all in a matter of minutes when I bothered to look.
It is a coolant pipe which is why the head gasket will blow if you let it lose fluid without fixing it. I have not looked into the coolant hose routings and what each do. I suspect the hose to the firewall is for heater core and the other route toward the passenger tire probably goes to the water pump or thermostat. The 5/8" barbed brass T-pipe is probably your best option. Replacing it with factory parts is really costly and short-sighted. It's a design defect and reliability issue that needs to be eliminated.
search this forum using key words "coolant brass" or "coolant y-pipe" or "coolant leak" or "coolant T-pipe"
search youtube using key words "2009 caravan coolant" or "2009 caravan hose" or "2009 caravan leak"
let me know if you can't find anything.
PS: If you don't know how to search this forum or youtube, please shoot me a PM and I will give you a lesson.
Old May 11, 2013 | 10:04 AM
Mac Bentley
Thank you, that's a great help. I certainly know how to search. I tried "plastic y-pipe" and got 24 returns of no use. I tried "plastic y" and got more than 400 returns.
Thanks again.
Old May 11, 2013 | 05:29 PM
georgef's Avatar
georgef
Here's one thread: 2008 grand caravan coolant leak
Here's another: part number for this coolant connector
George
