2007 Caravan
Old May 23, 2013 | 08:53 PM
Dber's Avatar
Dber
Default 2007 Caravan
Hi All,
Wondering if any of you folks would have some info on where exactly the Engine Control Module (ECM) is located on the 2007 Caravan.
I need the numbers off it in order to buy a new one..
A photo if possible would be a big help....then I'll know what to look for.
Thanks very much in advance..
Old May 23, 2013 | 09:24 PM
Cougar41's Avatar
Cougar41
The sly dogs put it forward in the driver's side wheel well. Have to pull back the plastic liner to get at it.
Old May 23, 2013 | 09:34 PM
Dber's Avatar
Dber
Default 2007 Caravan ECM Location
Thanks Cougar 41.
I got every number off the IPCM (Fuse Box unit) and it was the wrong Module.
I got every number off the BCM under the dash and they told me that wasn't it either.
I was at a loss trying to locate it but I did see a bunch of harnesses going towards the driver side fender and up under the plastic protective wheel covering.
Is there such a module as powertrain control module or is that the same unit as the engine control module..?
Thank you Dber
Old May 24, 2013 | 12:52 AM
Cougar41's Avatar
Cougar41
PCM is what Chrysler calls their ECM. PCM and ECM are the same animal on a Chrysler product.
Old May 24, 2013 | 01:06 AM
christheman's Avatar
christheman
I was wondering about that myself. No problems with the PCM so far, so I have not yet tried to figure out where it is. So do you pull back that plastic liner from under the hood, or from under the wheel well?
