07 Grand Caravan LF Turning Signal
Ok,
Current issue with my 07 Grand Caravan SXT.
LF Turning Signal bulb will not flash.
The light turns on fine when Parking or Head Lights are on.
Sometimes it works fine, most of the time it does not.
LR bulb flashes fine, and both RF and RR flash okay.
Tried a new bulb does not fix the problem.
Took bulb out of socket and unpluged socket from wires, no corrosion.
Can someone provide me with the wiring diagram for the LF bulb.
And any suggestions you all might have would be appreciated.
Thanks,
Mark
Thanks,
Mark
Don't recall if the front light assemblies have any part of the circuit built internal to it as the rear assemblies do. I would try swapping the left and right front assembles just to CYA. Other than that its the Body Control Module (BCM), connections at the IPM (fuse box) or wiring. The BCM is a pricey little box mounted under the dash against the firewall just left of the brake pedal so that makes it the last resort choice. Send me a private message with an email address and I'll send the wiring diagram.
