Grand Caravan 2007 Refrigerant Oil Charge?
Old Jun 8, 2013 | 04:09 PM
gabstero's Avatar
gabstero
Default Grand Caravan 2007 Refrigerant Oil Charge?
Hi Gang!
So i discovered that on my dual unit AC (front and rear evaporator) I need 2.38 lb or refrigerant capacity.
But I found nowhere saying how much oil I need (not in the manual or anywhere else like on the sticker).
Any clue how many ounces of oil should I add to a complete 2.38 refrigerant charge?
thanks!
gabstero
Old Jun 8, 2013 | 11:16 PM
RickMN's Avatar
RickMN
You won't find that spec because it doesn't exist. You replace the amount of oil that came out with the refrigerant. Sounds crazy, huh? Well, when a shop evacuates the system, the recovery machine separates out the oil and dumps it into a bottle. You measure how much oil came out and then put that amount back in.
If the refrigerant leaked out, you're in guess-land. And it all depends on HOW it leaked. If it was a big leak, a lot of oil can gush out with the refrigerant. But if it was a small leak, very little oil gets out.
Some guys add 1 ounce with a full recharge. But putting in too much oil causes a reduction in cooling.
So you'll have to call this one on your own.
Old Jun 10, 2013 | 02:55 PM
gabstero's Avatar
gabstero
thanks so much for the tip!! It was a full leak since I had a rear evaporator problem. I did a full system recharge (total of 2.38 lbs refrigerant for a dual system), and added about 3 ounces of oil.
The system works great. Thanks for the help!!
g
